- Grit_dogNavigator II^ This. Load it up...
- IdaDExplorer
jthrv wrote:
RobWNY wrote:
But that does not say whether the 1850 lbs is for a weight distributing hitch or a weight carrying hitch. On my 1/2 ton truck hitch label there is a huge difference 1500 lbs WDH vs 600 lbs weight carrying.
Do 2020 GM's have hitch labels ?
I don't think all of them make that distinction. I'm pretty sure my Ram is rated for 1800 lbs, WDH or not. - jthrvExplorer
Do 2020 GM's have hitch labels ? - BenKExplorerLabel on the reciever
- LwiddisExplorer IIDoor sticker has everything you need. So many buyers don’t review it prior to purchasing.
- RobWNYExplorerThat VIN decoder webpage really isn't vehicle specific even though you put in your VIN number. Many of the specs provided on that webpage show the same for all GM trucks. For instance, I have a 2020 2500HD Duramax Crew Cab standard box. When I use the decoder webpage with my VIN number it shows the same 500 pound rating but on the actual sticker it gives the vehicle specific numbers. This sticker is from my truck.
- agwillExplorerStandard bumper rating only, not made to really be used as is need to add a real hitch.
