BurbMan wrote:
blofgren wrote:
Exhaust brake - I played around with the settings on it, and even in full on and the transmission in tow/haul mode, it worked OK, but definitely not nearly as strong as the one in my Ram/Cummins. I would estimate it to be about half as strong, but I suspect that the one in my truck is super strong due in part to the manual transmission.
I wouldn't judge it based on this...it's entirely likely that the EB changes settings and gets more aggressive when you plug a trailer into the 7-pin connector.
It could very well be, but I had to use the service brakes several times on grades around the city in areas that I know I don't have to with my Ram/Cummins. To me, full on should be full strength whether a trailer is connected or not.
