blofgren's avatar
blofgren
2022 F-350 Demo Impressions
My work just took delivery of several 2022 Ford F-350 CC 4x4 LB XLT pickups with the 6.7L diesel and I had the opportunity to drive one for a couple of days while my F-150 was in the shop for maintenance.
A few impressions I had of the truck:
Power - wow, this truck has a lot of get up and go! Definitely a lot more than my detuned G56 Cummins Ram. The 10 speed auto is also very impressive with very defined shifts; it skipped gears (ie 1 to 3 and 3 to 5) when I first got it, but started going through every gear after about a day which I assume is the transmission still learning.
Cab - very nice with great visibility and very good ergonomics as everyone has come to expect from a Super Duty. I had forgotten how much I liked the side windows dipping down by the mirrors in the Super Duty. I also was surprised by the truck telling me to check for occupants in the rear seat after I shut it off; it turns out that it sensed my briefcase on the floor in the rear seat. Pretty cool feature!
Noise levels - the 6.7L engine is super quiet when idling, but the cab did have considerably higher levels of engine noise inside while driving than I expected. Maybe the higher trim levels have more insulation in the cab, but I'm not sure.
Exhaust brake - I played around with the settings on it, and even in full on and the transmission in tow/haul mode, it worked OK, but definitely not nearly as strong as the one in my Ram/Cummins. I would estimate it to be about half as strong, but I suspect that the one in my truck is super strong due in part to the manual transmission.
Fuel tank - I was shocked by the huge fuel tank; the truck had 1/4 tank and still took over 120 litres to fill it up. This would be great for towing.
Overall, it was a very nice truck and I can certainly see why so many people buy them. The truck itself was very solid and well put together, which Ford is well known for. It would have been great to keep it longer to get an idea of fuel economy, but unfortunately my F150 was ready for pick up then!
  • FishOnOne wrote:
    I've been resisting driving the new Super Duty's for a reason and with the 2023 Duty's coming up it maybe even more challenging.
    Also hearing some good things about the 7.3 that's produced by our friends in Canada.
    I definitely hear you on this! That said, the lack of negotiating power on trucks right now would likely be enough to keep me from making a silly decision! :B
    And for the 7.3L, we have several of them at my work that get worked hard and we have had absolutely no issues with any of them. They have pretty good power, and sound fantastic too!
  • BurbMan wrote:
    I wouldn't judge it based on this...it's entirely likely that the EB changes settings and gets more aggressive when you plug a trailer into the 7-pin connector.
    It could very well be, but I had to use the service brakes several times on grades around the city in areas that I know I don't have to with my Ram/Cummins. To me, full on should be full strength whether a trailer is connected or not.
  • I've been resisting driving the new Super Duty's for a reason and with the 2023 Duty's coming up it maybe even more challenging.
  • Very detailed, objective report. TY for posting.
