tattoobob
Sep 28, 2016Explorer
tattoobob wrote:
Horizontal tanks are exempt from the OPD Law and the old valves are fine
I can't seem to find what the old code says so they must have changed it in the newer codes to date,
2-3.1.5 Cylinders with 4 lb (1.8 kg) through 40 lb (18 kg) propane
capacity for vapor service shall comply with the following:
(a) * Cylinders fabricated after September 30, 1998, shall
be equipped or fitted with a listed overfilling prevention
device and a fixed maximum liquid level gauge. These
devices shall be part of the container assembly. The length of
the fixed maximum liquid level gauge dip tube shall be in
accordance with 4-4.3.3(a).
(b) Cylinders requalified after September 30, 1998, shall
be equipped with an overfilling prevention device and a fixed
maximum liquid level gauge prior to being filled.
(c) Effective April 1, 2002, no cylinder shall be filled
unless it is equipped with an overfilling prevention device
and a fixed maximum liquid level gauge. The length of the
fixed maximum liquid level gauge dip tube shall be in accordance
with 4-4.3.3(a).
(d) Cylinders required to have an overfilling prevention
device installed shall be equipped with either a CGA connection
number 791 or a CGA connection number 810 as
described in CGA Publication V-1.
Exception: All cylinders used in industrial truck service (including
forklift truck cylinders) and cylinders identified and used for industrial
welding and cutting gases shall be exempt from these requirements.
44,072 PostsLatest Activity: Aug 23, 2026
