ticki2
Sep 30, 2016Explorer
Steve_in_29 wrote:Reddog1 wrote:Steve_in_29 wrote:tattoobob is correct. I have older horizontal tanks in my 5th wheel, no problem having them filled. The first 2 to 4 years it was touch and go. I have a PDF somewhere that explains it all.tattoobob wrote:
Horizontal tanks are exempt from the OPD Law and the old valves are fine
I am pretty positive that only chassis mounted horizontal tanks are exempt not the portable ones like the OP has.
Wayne
Even if correct the information isn't applicable or useful to the OP's situation as his tanks need to be re-certified (not converted) which every tank except chassis mounts need to comply with.
Here is another fly for the ointment . The reason the chassis mount are exempt from re-certification is they are ASME tanks , not DOT cylinders .
