dbbls
Jun 13, 2013Explorer
Unless you go to a load range G tire you will not have the carrying capacity you had with your ST tires. You need to weigh your trailer loaded like you normally run and see if E rated LT tires will be enough. To answer your question, I have found two LT tires that are equivalent to your St tires. One is the Goodyear G614, and the other is Sailun S637. Both are 14 ply rating (load range G) and can carry 110 PSI.
