- Tundra2084ExplorerWe had to find ours at a Truck Tire dealer. The Sailun 637s are available in both the 80 and 85 size. Tried to find them at local tire dealer and was told because they are used on commercial trailers they could be found at a dealer that sells to the big rig semi's at least here in Ontario Canada.
- blofgrenExplorerI've had my Sailuns for over a year now and they still look brand new. They are an extremely heavy duty tire; the shop that mounted mine said they were very hard to mount because the sidewalls are so stiff. I have yet to read anything negative about them and recommend them without hesitation.
- momentum_rvExplorerMy Sailuns are still going strong!
- mudmakerExplorerJust ordered a set from Simple Tire and mounted them myself. Really impressed so far.
- fj12ryderExplorer IIISo far there have been no reports of failures of any kind of the Sailuns that I have heard or read about. They've been out there, and in increasing numbers and it's looking very good.
- justmeExplorerHow does Sailuns compared the other reputable brands? Does anyone have some real data on reliability/durability. I need a set to replace my Goodyears that served me well--- albeit pricy.
- lazydaysExplorerUnless you have clearance issues go with the 85's. I just put a set on Friday and the difference was minimal.
- boiseidahoExplorerHere is Boise Les Schwab carries Sailun tires
- SlickWillieExplorer
Helmsey wrote:
If you have a local Discount Tire they should be able to order them for you.
I tried that with no luck.
About Fifth Wheel Group
