StirCrazy
Feb 11, 2023Moderator
Huntindog wrote:Groover wrote:Oh Snap.I post something good and crazy gets the credit!
As StirCrazy said "There is more than the cost to measure value. Being able to increase range by 25% is worth something."
Not having to stop as often or worrying about giving out of fuel is nice. In virtually every discussion here about electric vehicles range is a key item. While it is less of an issue with diesels it is still an item.
If you are satisfied with your current range then you could carry 20% less fuel and increase your payload by 70lbs in a Superduty with the 48 gallon tank, or a 120lbs in my class A. Less time at the pump when you stop would be nice as well. Or don't use the extra weight capacity and have better performance.
A similar savings in DEF was reported. That is also worth time, weight and money. It is really amazing to me how some people blow off savings. It is almost like they are proud of how much they spend.
OP, huntindog.:B
"Being able to increase range by 25% is worth something."
:B I had to scroll back to see how that one came about haha
