45Ricochet
Feb 23, 2014Explorer
wmoses wrote:ricatic wrote:
He is looking at a Ford....no difference in brakes, axles or suspension other than the 350 has the overload leaf in the rear that only engages when a heavy load sags the truck to it's level...also the 350 has a 2" thicker block between the rear axle and the spring pack...seeing that he is looking at gas...he might have a warranty...
Added to the above - the F350 has a bit harsher ride than the F 250, which has quite a comfortable ride. This based on two sets of test drives with both trucks back to back.
Please explain :B The over load springs don't come into play until a load is placed onto it requiring action to compensate for the load, correct ? I'm no Ford guy but generally that is the main difference between the two. I'm all ears !
44,066 PostsLatest Activity: Apr 16, 2026
