dcpac
Dec 31, 2015Explorer
2500 Ram payload
I am buying a Ram Outdoorsman crew cab with the 6.4 Hemi and 4.10 axle. The Ram website states the payload is 2926. Does anyone know if this payload is true? I worry there is some small print or some...
SouthpawHD wrote:jus2shy wrote:SouthpawHD wrote:
Seems kinda high from what I've seen. Some of quoting your own payloads, do you have 3/4 ton crew cabs?
I've checked a few Ram 2500s, and a moderately equipped CC is usually around 2100 pounds.
To have payload that low, it'd have to be a diesel. OP is running a gasser which is about 800 lbs lighter for the same 10,000 GVWR that 250/2500 series trucks are limited to.
Wow! Didn't realize that the diesels took away that much.
