dcpac
Dec 31, 2015Explorer
2500 Ram payload
I am buying a Ram Outdoorsman crew cab with the 6.4 Hemi and 4.10 axle. The Ram website states the payload is 2926. Does anyone know if this payload is true? I worry there is some small print or some...
wilber1 wrote:spoon059 wrote:wilber1 wrote:
So you are saying you can put a 20K GVWR on a 3/4 T truck as long as you pay for it?
Correct. You are LEGAL for whatever you paid to register, so long as you have sufficient tire ratings for your weights. My Tundra had a GVWR of 7200 lbs. In Maryland you can register for 7000 lbs or 8000 lbs. My Tundra was registered for 8000 lbs, so I could legally drive 800 over my warranty card (yellow sticker) weight and there was nothing the police could do about it. I had E rated tires with over 12K rating combined. If I wanted to, I would have registered to 12K and towed a 5th wheel LEGALLY.
I would have some explaining to do when I tried to get my axle replaced under warranty though :)!
In my post I didn't actually say anything about being legal, that was someone else's claim. What I said was, he will be way over the limits set by the manufacturer of the vehicle. If some of you are OK with just pulling numbers out of the air and declaring yourself safe because some DMV clerk will give you a registration at that weight, go right ahead but you are deluding yourselves.
