mr70ss
Aug 19, 2015Explorer
2500HD and a 4000lb camper...
Ok so I've been digging around on the forums for answers, and now it's time to get a consensus on what I have come up with...
truck specs and weights
09 2500HD Z71 CC LB 6.0 gasser
285/65/18 toyo at2 (3640@80psi max)
Dick Cepek 18x9 wheels (3640lbs max)
Torklift frame mounts
Torklift stable loads
Firestone airbags
Super springs SSA15 (5000lbs)
Weighted the truck with a full tank and me and the wife, here are the #'s
front axle 4040lbs
rear axle 3080lbs
total 7120lbs
camper specs
adventurer 910fbs
3284lbs dry (inc. options)
4228lbs wet (inc. 50g water, 40lb pro., batteries & 300lbs misc)
47" COG
so I found a great little camper weight site http://www.visualsc.com/tc_calc.htm
I put all the numbers into the calculator and here is what I get back..
rear axle 7077lbs
rear tire 3538lbs
front axle 4271lbs
front tire 2135lbs
gvwr 11348lbs
Now I do know that in this model when you add the water weight, it will move the COG forward.
from all the searching I've done the only differences from a 2500 to a 3500 is the spring pack (extra overload leaf) and wheels and tires, 16" to 18".
My question is am I wrong in figuring my rear axle is now 7280lbs (both wheels and tires are 3640lbs max X 2)? I know i'm way over on that the door tag shows for gvwr & gawr, but I assume those numbers are for a factory stock setup.
Firestone airbags
front axle 4040lbs
rear axle 3080lbs
total 7120lbs
camper specs
adventurer 910fbs
47" COG
rear axle 7077lbs
rear tire 3538lbs
front axle 4271lbs
front tire 2135lbs
gvwr 11348lbs
