LL8's avatar
LL8
3.42 gears for TC
Hello,
Just looking for some thoughts on pulling hills with 3.42 gears.
I'm going back to a pop-up TC @ 1800 lbs dry weight.
The trucks I'm looking at are the Chevy and GMC 3500's SRW 4x4, standard bed, crew cab, with the 6.6L diesel.
Their payload rating in 4185 lbs
They only come with a 3.42 gear option but have a 10 speed Allison transmission.
And I like the 20" wheels just for the looks.
Do you think this will be an issue hauling up mountain roads and interstates (East Coast) at closer to 3000 lbs fully loaded? Or should I look at the other competitors with a 3.73 option?
TRANSMISSION & AXLE
Thanks for the advice
Type: Hydra-Matic 6L90 six-speed automatic (6.6L gas)
Allison® 10L1000 10-speed automatic (6.6L diesel)
Gear Ratios (:1): 6L90 10L1000
First 4.03 4.54
Second 2.36 2.87
Third 1.53 2.06
Fourth 1.15 1.72
Fifth 0.85 1.48
Sixth 0.67 1.26
Seventh -- 1.00
Eighth -- 0.85
Ninth -- 0.69
Tenth -- 0.63
Reverse 3.06 4.54
Final Drive Ratio:
3.73 (6.6L gas)
3.42 (6.6L diesel)
  • I don't think 3.42 will be an issue with one of the newer diesels. Worst case, it will downshift going up mountains. On the other hand, my 4.30 gears never downshifts but runs at a lot higher RPM using more fuel even when empty.
    If I was you, I'd look at the tire capacity of the sizes for the brands you like. You may find the 18s to be a better choice for a SRW. I'm assuming you are talking about SRW since you mentioned 20s.
