trailer_newbe wrote:
I’m going to settle this. My company provided F150 with the 3.5L twin turbo is awesome. I had to tow a large maintenance trailer, empty, 500 miles. This trip I’ve done 100 times without a trailer and had 4 days of fuel once back in town. Towing a trailer taught me one thing: the 3.5 TT is awesome but as soon as those turbos need to wind up, kiss gas mileage GOOD BYE. I had to re-fuel just to get back in town. Go normally aspirated gas when towing in regards to gas engines. Turbos are great but they are like a fire hose when loaded.
Pulling a load DOES take fuel. The turbos do increase fuel usage, which is why ford doesn't have them kick in unless you punch it. The turbos also let you keep most of your power at altitude. It is a trade off. If you stay light on the gas pedal, the 3.5l EcoBoost gets good gas mileage. ANY tow vehicle pulling a 10,000# wind sail will get crappy gas mileage. Personally, I would never "{g}o normally aspirated gas when towing in regards to gas engines." Turbos "are like a fire hose when loaded", but they are great at keeping power at altitude. They are also the reason you have your power band at about 2,700 RPM rather than 4,000 RPM and above.
Comparing the truck on that run pulling no trailer vs pulling a trailer is not a good comparison to determine if the turbos are the problem. You need to try that run pulling a trailer with a turbo engine vs a NA engine. Then you would have a meaningful comparison. I would not be surprised if the NA engine had MPG almost as bad as the turbo, but ran at 4,000 RPM while doing it.
What actually cost you your gas mileage was the big wind sail you were pulling, not the turbos.
