wrvond
Mar 31, 2018Explorer II
I was using my twenty-something year old Reese weight distribution hitch with 2" shank, which meant I had both sleeves installed. There was a lot of slop in this set up and I bent the 5/8" diameter Reese locking pin I was using.
I then purchased a Blue Ox Sway Pro with 2000 lb. bars and a 2.5" shank. I had to use the OEM pin for a while, but it worked with no issues. I have since purchased and installed a Bolt locking pin. I must say it is pretty beefy, and the pin looks much more substantial than anything else I have seen to date - including the OEM pin.
I did a bit of research prior to my purchase of the Sway Pro. Nobody, with the possible exception of Gen-Y makes a WDH with a 3" shank.
I decided against the Gen-Y hitch mostly because it doesn't seem to really be a purpose built unit. The weight distribution assembly seems to simply slide over the shank in some way that really wasn't clear to me.
There still appears to be some up and down movement allowed, which I don't think adversely affects anything. However, since I will probably not ever purchase a three inch shank, I am considering doing a few spot welds on the back side where the 2.5" insert meets the 3" receiver.
44,054 PostsLatest Activity: Dec 18, 2025
