Lynnmor
Apr 01, 2018Explorer II
CarterKraft wrote:
I could drill the receiver now as it's new centering a drill bit won't be a problem but then you will have to get a ball mount that will take a 3/4 pin.
The 3” receiver on your truck should be 3/4” already, that’s the problem. The shank and adapters need to be 3/4” so that s 3/4” pin will fit each part correctly. A machine shop can do the machining for you and get it right. It is not unusual for the factory holes to be rather crude.
I suspected all along that folks were using 5/8” pins in the 3” receivers and that is a real problem.
44,054 PostsLatest Activity: Dec 18, 2025
