Mike_Up
Jul 23, 2016Explorer
brulaz wrote:
Did you pressure up your P tires to max?
And what is that max?
Seen some newer P's with over 50psi max. which should help with side flex and towing.
I actually went to 35 psi on the tires. The max is 51 psi but not sure how much tread would reach the pavement at that high of a pressure.
With my previous '12 F150 and LT BFGoodrich T/A All Terrain KO2s, going up to 52 psi didn't allow the row of tread next to the edge to meet the pavement using the chalk test. 47 psi was good for complete contact.
I'll have to do some research and make sure higher pressures will help and not hinder.
Thanks
44,052 PostsLatest Activity: Oct 09, 2025
