lots2seeinmyrv wrote:
TundraTower wrote:
Before there's any more insults, the Tundra is the nicest, best performing, best handling, most reliable truck I've ever had. I bought 7 new chevy's over 33 years and finally gave up on their quality and went to Toyota. Never had a problem and it's done everything we've asked it to do, including pulling that trailer over the continental divide 4 times.
This is the most un-excited I've ever been about trading vehicles. But we need more capacity and Toyota doesn't make a 3/4 ton. If they did, I'd already have it.
I was concerned about gas mileage because the 3/4 ton itself weighs 1200 lbs more than the tundra, has less HP (360 vs my 381), and has a taller gear ratio (4.1 vs 4.3 in the Tundra). All of those numbers are going in the wrong direction for power and gas mileage.
x2
You may be letting the gvwr have way too much influence over your decision to change vehicles. If you had different numbers on your door sticker would you be satisfied with your truck?
