- blt2skiModeratorTransamz9,
Hard to ddisagree on your points. Reality is, most 25 series trucks are more capable than a dually from pre 2000 or so.
I've run down the road in the 10-12k range with the 2000. That's about max, based on graw, and front ability. The new ones do have another 2000 lbs of axle capacity. They still weigh more. Sit higher etc. For a lot of us, that 8600-9000 lb truck like the 2000 I drive is nice. My 05 max dually CC had 400 more lbs of payload per door sticker....it would carry a lot more. I could easily put 7-8000 in the bed.
Marty - Me_AgainExplorer III
FishOnOne wrote:
Looks like you could have used a LWB truck, but then again would loose some load carrying capacity.
LWB was long for the garage at the time, and would not fit in the Az park model car port and leave room to walk around the front of the truck. DW did not want a dually or long box. - transamz9Explorer
blt2ski wrote:
4x
Remember you have a crew cab. My 2500 with a rev cab and SB8 has 3800 lbs of payload. Granted a really base stripped model.....
If folks did not ask for floor blown leather etc interiors, one would have more payload....
My 96 SW K3500 had just shy of 3000 with a nice mid trim cloth interior, 6.5TD and long bed. My tare was 6500 lbs or so. Today's rigs are at minimum 1000 lbs heavier. I can't find a base rev cab 2500 that weighs less than 5800 lbs. Mine is 4800 lbs. We have more GVW, but worst payload!
Marty
We may have worse payload buy the numbers but capability is light years ahead. If you say you have found a new 2500 that weighs 5800 then I would have no problem loading the truck to 11,000#. 5200# on your old truck that weighs 4800 would have a hard time handling 5200# running hwy and interstate speeds comfortably. Me Again wrote:
ShinerBock wrote:
Me Again wrote:
CampingN.C. wrote:
Just speaking on ride quality alone, my new dually rides better than my 15 2500 with coils did.
And for the weight po-po...I towed a 42ft toyhauler just fine with a 3000lb pin weight on a 2500.
Sure you did, however you were most likely over the 6500 RGAWR of the 2500.
A 3k pin weight should not put a Ram 2500 diesel with a rear GAWR of 6500 over its rating. Even though the truck is almost 8k, a little less than 3k is in the rear so adding another 3k would give you a little over 500 to spare. Of course adding passengers would take away from that 500, but a lot of that weight will go towards the front axles that is rated at 6k GAWR on the diesels.
I am at 3760 on rear axle ready to tow. That is Demco 6099 picture frame and B&W manual slider(270 lbs), no tail gate, V-Box in back of bed with two sets of golf clubs, front box full of tools, Honda EU2000i, 6 gals of diesel, two gallons of gas. Stuff just adds up.
My pin weight is around 3K which is light for a 16K 39'4" 5er. Dry weight on this model in 2435 which 18+% of dry weight.
Looks like you could have used a LWB truck, but then again would loose some load carrying capacity.- blt2skiModerator4x
Marty - 4x4ordExplorer III
ktmrfs wrote:
4x4ord wrote:
In my opinion offering a 3/4 ton HD diesel is just plain stupid. By the time you load a small family and a hitch in the bed of a diesel 3/4 ton you haven't got enough payload left to pull more than a tent trailer.
really???? on my GMC Denali 3/4ton duramax crew cab 4x4 I can put two motorcycles in the back along with firewood camping gear and 3 adults along with the tongue weight of a 9,000lb trailer (1450lbs) and going over the scales I'm still under 10K lbs. Even my denali, with all the extra's has 2600lbs cargo capacity
Now had a 1 ton short bed SRW crew cab been available I would have bought it, but virtually all the 1 ton SRW in 4 states were long box.
Exactly. So why does the dealer even bother ordering in 3/4 tons? Apparently the Ford is even heavier than the GM. My F350 only has a 3300 lb payload rating with a 11500 GVWR. So a F250 equipped like mine but with only 10,000 lb GVWR would only have a payload of 1800 lbs. Take off 1200 lbs for hitch, family, fuel and a little bit of miscellaneous and you haven't got much left for tongue weight. When it come to towing a fifth wheel it doesn't take much to eat up 3300 lbs let alone 1800. These SRW diesel trucks are designed to tow 18000 lbs .... you need carrying capacity (heavy springs) to make use of that potential. 3/4 diesels should not be offered. - ktmrfsExplorer III
Now had a 1 ton short bed SRW crew cab been available I would have bought it, but virtually all the 1 ton SRW in 4 states were long box. - Me_AgainExplorer III
- ShinerBockExplorer
A 3k pin weight should not put a Ram 2500 diesel with a rear GAWR of 6500 over its rating. Even though the truck is almost 8k, a little less than 3k is in the rear so adding another 3k would give you a little over 500 to spare. Of course adding passengers would take away from that 500, but a lot of that weight will go towards the front axles that is rated at 6k GAWR on the diesels. - ppineExplorer IIIOne man's syncline is another man's anticline.
