transferred wrote:
taken wrote:
gazingm42 wrote:
In my decision last year I was debating over the ram 2500 vs 3500... I went with the 3500 simply because of the payload difference. I hear folks say there is no difference which simply not true. With the payload there is springs or cool changes. If you ever pull a 5th down the road I want the 3500..
Again, this depends on brand. With Ford, there are no springs or "cool changes." Same truck.
Is there no longer the extra overloads? There used to be. If so, are the springs the same width and thickness?
As SB posted, if you order the camper package with the 250 you get the overloads and taller spacer block. The main spring pack is the same either way.
