Acei's avatar
Acei
3/4t vs 1t differences
I realize there has been many questions asked about this and I have read quite a few but still doesn't really answer my curiosity completely, so here it goes...
Say if I need to use the truck 60-70% of the time not towing and expect to use it daily on all road conditions including typical North East potholes, do these two make much differences? Or does brand make more difference? From my understanding, GM models ride the best...
  • I'm not sure about Ram and GM, but with Ford the SRW 350 is identical to the 250. The only possible difference is a single upper overload spring and a taller rear spacer block under the suspension. Both of these items can be had on a 250 as well based on packages ordered. They can also both be added after the fact for cheap money. With Ford, the 250 is de-rated on paper to fill a different market segment is physically the same truck. That said, the two will ride identically...
    When buying new and ordering I would and did go 350 as the price difference is less than 800 and someday states may start checking private rigs for weight. If I was buying off the lot and found the perfect deal on a 250, I wouldn't hesitate to grab it though.
    As to ride, I would say either Ram 2500 with it's full air suspension option, the Ram 3500 with it's rear suspension, or any GM product with IFS will ride better than a Ford SD. I'm hoping Ford comes out with some ride enhancement in the 2017 re-design without sacrificing strength.
