OutdoorAddict
May 18, 2018Explorer
I have had a 2500 with air and now a 3500 DRW with air. The 3500 is much better than the 2500 because it works with leaf springs. True, currently there are no after market suspension products that you can use with the factory air ride, but I have found no need to upgrade the suspension and I am hauling a AF 1150 and often tow a boat. The Only downside to the air is that you cannot add air to just one bag to offset the additional weight of the slide, I have a very slight list to the side of the slide with TC on truck. I don't think cold weather affects the air bags because the bags work on a closed system and are filled with nitrogen.
