edatlanta
Apr 25, 2016Explorer II
It was mentioned above that 5200 was hard to remove. I would say it is virtually impossible to remove without severely damaging whatever it is cured to. One time, on a boat, I needed to remove a failed through hull transducer. It actually had to be cut out. Somewhere I found a product that was supposed to dissolve 5200. It didn't.
I would caution against ever using 5200 on an RV unless whatever it was attached to can be easily removed and replaced because the 5200 definitely isn't.
