DanNJanice
Apr 25, 2016Explorer
edatlanta wrote:
It was mentioned above that 5200 was hard to remove. I would say it is virtually impossible to remove without severely damaging whatever it is cured to. One time, on a boat, I needed to remove a failed through hull transducer. It actually had to be cut out. Somewhere I found a product that was supposed to dissolve 5200. It didn't.
I would caution against ever using 5200 on an RV unless whatever it was attached to can be easily removed and replaced because the 5200 definitely isn't.
X2!
While I think the 4200/5200 products are some of the best on the market, I cannot imagine using them or the other marine adhesives on an RV. Most leaks are likely to be in the roof area or roof penetrations. Things like skylights, vents, covers, etc need to be periodically replaced. Having them glued down with 5200 would almost insure a major battle/damage removing them.
