Lynnmor
Sep 20, 2019Explorer II
Me Again wrote:Lynnmor wrote:Me Again wrote:
. What you think you gain with the lower diff gears in negated by the steeper OD ratio. Think final gear ratio!
Keep in mind that the transmission is worked harder with higher diff gears.
You multiply the top gear ratio times the diff gear ratio, and the result is always more torque with the lower rear gears. Add to that, each gear change is less of a difference in road speed, keeping the engine at a better RPM.
That basically applies in first gear to get a load moving.
Out on highway one is in 5th and the other in 6th at the same speed. You are dismissing a taller 6th gear od ratio.
I am not dismissing anything, the multiplier (rear gear ratio) is the same in every gear.
