westend wrote:
... make sure any 4 banger is equipped with the right towing package, i.e. correct rated hitch, tranny cooler, brake controller, and trailer electrical connection.
CONCUR !
Probably the most important of the above is an auxiliary transmission cooler. Check to see if it was an option. Adding a factory cooler is usually cleaner than an aftermarket. If there was a HD radiator option, that would also be a good upgraded.
Most very small trailers do not have brakes. You may decided to add them and a brake controller after you tackle some hills.
Whether you need a weight distribution hitches depends on the trailer tongue and what you are hauling in back
(i.e. how much sag at the hitch)My EcoBoost turbocharged 2.0L Ford Edge is rated at 3500#. I think that is "generous" but I would be comfortable around 3000#.
