BurbMan's avatar
BurbMan
Explorer III
Dec 07, 2013
4L80E Cooler Lines
Confirmed that the radiator is leaking due to a crack in the plastic tank on the drivers side. New radiator ordered, and looking at what else I should replace as part of the job. The engine oil cooler lines are fine but the transmission cooler lines are leaking at all the crimps. This truck (in signature)actually has 2 trans coolers, one in the radiator and another external cooler that sites in front of the a/c condenser. So the cooler lines go from the trans to the rad, the rad to the external cooler, and then back to the trans, 3 lines altogether.
Anyone offer any pointers/advice on changing these lines? I just had a Jasper rebuilt trans installed in Sept and asked them to check the cooler lines and thought for sure they would replace them but they didn't. They did say they flushed the lines and coolers prior to installing the new trans.
Are these lines hard to get out of the transmission?
This is the line coming out of the top of the radiator, this is typical of every place hose is crimped to hard line on all 3 lines. Should I replace them or leave them?
