jalabuff1's avatar
jalabuff1
Oil Cooler Line
Please help locating oil cooler line for 2001 Georgia Boy Suite with a workhorse chassis, mine is leaking and need to replace it. Local parts store cannot get it. Any help would be appreciated.
  • Find a Parker Hydraulic hose dealer and they will make a new one modelling from the old one. Bulldozer hose. Weill never wear out. Try CAT dealer also or maybe some implememt dealers around you.
    http://www.yellowpages.com/greensboro-nc/mip/parker-hannifin-5863675?lid=5863675
  • If it is leaking by the entrance to the block or filter, it could be the line adapter which you can get at many auto parts stores under the Chev listings. Same with the steel lines. They are not specific to Workhorse but to GM.
    This is what I got from O'Reilly's for my 7.4
    Cooler line
    Oil cooler line for 8.1 Chev
  • What engine?
    Almost any hydraulic repair shop can make you a new line. Are you sure that it is the hose leaking or is it the fittings on the engine block. The fittings are easy to find and fairly cheap.
  • Not the most convenient solution, but...
    There will be a farm implement shop within 100 miles of you. Take the offending hose off, and take it there. They will be able to make you one, maybe even while you wait if they have the fittings in stock.
