dodge guy wrote:
YamaDooed wrote:
dodge guy wrote:
~DJ~ wrote:
YamaDooed wrote:
If you leave the trans in OD towing over 6000 lbs any distance your trans should be needing rebuilding shortly regardless of your axle ratio. And yes your mpgs will increase also.
A friend of mine lost his tranny not realizing he should tow with OD off.
I've been towing in O/D for years and no problems. Of course the 4.30's help in that department!
Funny how some people give advice on something they have never tried for them selves.
Yes you can drive with it in OD if you have a V10 but the 5.4 with a 3.55 will be shifting in and out of OD and your trans temps will be going thru the roof. And Yes I've tried it many times esp. with fuel over the $4 a gal years. :)
And that is why you go to 4.30's and enjoy the new found power band! The truck will work less and instead of running at 2700 in 3rd you can run 2300 in O/D and let the truck relax! Yes a few hundred rom makes a huge difference!
Total BS.
I have NEVER felt the "need" to turn off the O/D with my 2003 5.4, period.
The owners manual only states to turn the O/D off IF (AND THAT IS ONLY IF) the transmission is CONTINUALLY HUNTING gears (IE downshift then immediately UPSHIFT then downshift then upshift and so on.
That 4.30 is not going to buy the OP much if any "relief" for gas mileage, take off speed or down shifting.
The OP HAS a very heavy truck and the 2V 5.4 is rather weak for the weight of the truck for the 2V years..
The OP needs to simply understand that the truck will pull the trailer but not at 65 MPH going up hills in O/D. It WILL downshift REGARDLESS of the end gear ratio when going up even light grades.
Op also needs to understand that 4K and even 5K RPMs is NOTHING to that engine.. It CAN and will operate at 4K and 5K RPM ALL DAY without harming anything (there is no push rods to bend).. Yes it does make some noise but it will not damage the engine OR the transmission..
My 2003 has almost 200K miles on the clock, many miles towing and the engine never uses a drop of oil between changes (6K miles using Dino oil) and the transmission still shifts and operates like it came right off the lot..
Patience and a light foot will go a LONG way in making that year of 5.4 pull the load.. It isn't going to win any races but it will get you from point A to point B..
The OP has a 14 year old HEAVY truck, just not worth dumping money into a gear change (especially if a 4x4 where you will pay X2).
If OP is that dissatisfied with their vehicles performance they may wish to consider buying a new or newer truck with a 6.2 or even find a 2005 up truck with the 3V 5.4 instead of dumping money into a 14 yr old vehicle.. Night and day difference between the 2V and 3V 5.4s.. But the real eye opener is the 6.2 which simply rocks.
