VintageRacer
Dec 13, 2015Explorer
Google found this in three minutes...
1993 Chevrolet/GMC C3500 Pickup (2WD) 6.5 V-8 Turbo-Diesel 9000 lb
Notes: Requires Z82 Trailering Special Package. Requires automatic transmission._ Requires engine-oil cooler._ Requires transmission-oil cooler._ Requires weight-distributing hitch._ Requires 4.56:1 axle ratio_ Towing not recommended with GMC Typhoon._
http://trailers.com/tow-capacity/index.php?action=do_search&year=1993&make=Chevrolet/GMC&model=C3500%20Pickup%20%282WD%29&template=normal
That is 9K lbs for the gross trailer weight, regardless of tag or fifth wheel. I'd personally presume that hitch weight won't be much of an issue, but you do need excess payload capacity of 2,000 - 2,300 lbs.
44,066 PostsLatest Activity: Oct 04, 2013
