T diesel wrote:
With that mileage injectors are not far off.
You will need a water pump soon.
The front end with that mileage is suspect.
stc fitting changed to the new upgrade?
How's the alternator?
$5000.00 may be light!
You guys really should put a wrench in your hands and turn them once in a while.
First off with any decent SD truck get an OASIS report run. That will at least during it's warranty period show any work done to the truck.
Water pumps - again even if a coolant change has only been done once in that mileage it's more than likely good and if not....well they don't cost $500 each and are doable by a decent shade tree mechanic.
Front end - well even the SD's front end parts don't last forever. Just did the upper and lower BJ's and U-joints on mine this past summer along with outer tie rods. A lot of work but I would not have paid someone else to do it.
Alternator - Reman's cost about $120 and take all of a half hour to R&R. The truck loves batteries and alt's
Really I'd only buy ANY used diesel from any of the 3 manufactures if and only if I had deep pockets OR don't mind turning a wrench.
If you don't have or like to do those things buy a gasser or buy a new truck. It's just not possible to buy a used diesel truck and not have to look forward to repairs and maintenance.
