mtofell1 wrote:
Turtle n Peeps wrote:
Of course, the Dmax had more overall power but the 6.4 is more than adequate for the 8500lb TT. EVERY other aspect of the Ram I like better.
It might have felt that way because of the low down torque but 410HP hemi will beat 360HP diesel towing. It will do it at a higher RPM but that is just the way it is.
I'm thinking some will disagree with this statement. I've always been under the impression that torque is what wins the race towing. From driving both trucks I'd stand by that. Dmax was 360HP/650 torque, Hemi 6.4 is 410HP/430 torque and the Dmax had more acceleration up hills (accelerating from 40-60 up a modest grade, for example). They seem pretty equal from a dead stop on flat ground but the Dmax up a hill with the same load would win hands down.
In any case, both moved the trailer great and I know I'm way under the capability of both trucks with my moderate sized TT.
I think you're 100% correct with some people disagreeing with that statement but that doesn't make them correct.
My 200/425 6.5 diesel would be crushed by a 300/370 6.0 gas engine in a tow off. Even though the diesel puts out over 50ft/lbs of torque.
The 410HP/ 430 torque hemi would annihilate a 325/610 Cummins in a tow off even though the oil burner has almost 200 more ft/lbs of torque.
HP is how fast work is done and that says how fast you're going up the hill and how fast you're going to be going at the top of the hill.
