JBrady5555's avatar
JBrady5555
6.4 ram gasser? General gas towing questions
Hello folks, first time poster here, if this post looks a little weird it's because I copy and pasted from a post I made at the bobistheoilguy forum. They referred me here, looking forward to joining the community here.
Hey folks my last few posts here at bitog have been about finding a good used 3/4 ton diesel to upgrade from my f150 2.7 eco. I'm having a hard time finding a good pre emmissions truck in my price range that isn't junk and many people here have recommended a gasser which honestly I didn't really entertain. I'm now thinking that may be a good option considering towing mpg between the gassers and the diesels are almost identical from my research.
I'd love a 6.2 f250 but they are hard to find used and when you do they are just about as expensive as the diesels. I've been looking at the 6.4 rams which seem to have good reviews and I wanted to see what this community thought of that engine/drive train combo? Does dodge still have weak transmissions? The 6.2 seems to out class the 6.4 but the ram hits my price range in the low 20ks far more often than I can find the f250s.
For the record my f150 tows my new 7600lb gvw 33ft travel trailer pretty good but I'm up against payload and weight and I'd really like to add a 50 gallon tank in the truck bed so I don't have to weasel in and out of tight gas stations every 150 miles. Would be far easier to fill up in a rest area with a added tank.
Looking for any info on gas vs diesel towing, hoping to be convinced that gas is a viable option for me(full time rver, 15k a year/60% towing). Any info on the 3/4 or 1 ton gassers, especially the ram 6.4 would be appreciated. Also any info on aux tanks for gassers would be great, if I'm not mistaken all gasoline tanks have to be manually pumped right?
Thanks
    I don't know how you did your research or where you got your info but you're flat out incorrect.
    Modern diesels will net you about 25 to 27% better mileage. Before emissions they would net you around 30%.
    That said, the Ram gasser is a nice truck. If it fits your needs then I would consider it.
