IdaD wrote:
Auto coupled with tow/haul when towing is awesome going down grades because it holds whatever speed you set with a brake tap or taking your foot off the accelerator, adjusting the amount of compression and/or downshifting as necessary. Even on the big grades we have out west the only time I have to use my brakes is when I need to slow down for a corner, traffic, etc.
I do use my EB when I'm not towing if I remember to turn it on, which is not all the time.
Try it with 26k behind you going down a 6% great. It will NOT hold.
I run TH and FULL EB and use cruise and lock out the same gear I would have came up the grade. I set around 50 for holding 55 in 3rd on 6% grades.
I can go down several miles of 14% locked in 2nd with cruise set to 30 or so and be running 35mph.
