vacuumbed wrote:
mccrawwf wrote:
Please give your thoughts, or the the best financial and safe move for the future. I have a 2005 Ford 3500HD 6.Ol Deisal truck that I pull a 34 ft. Jayco 5th. wheel. Iam aware of the problems with my truck and the more I read the sicker I get. At this point-98K miles-no problems. Based on 2 estimates Iam looking at 6K to 10K to fix the problems before they happen. What is best-trade or fix? If I trade Iam going to a Dodge Diesal. Iam 63 years old and hope to RV till around 75. My trips are limed to a couple of trips to SC a year.
Tks! Bill
Bill,
Spending 6K or more to fix problems that are not there in my opinion is a bad idea. If you keep it, I would spend less than $500. Here is what I would do if it was my truck.
1. Do your oil changes at every 5,000 miles with full synthetic 5W/40 oil. Your 6.0 injectors will love that oil. Use ONLY the Motorcraft oil filter.
2. Install a coolant filter. Cost is about $150 if you do it yourself. These aren't too hard to do.
3. Flush that Ford Gold coolant out of there and put in CAT ELC with distilled water.
4. Keep your fuel filter clean and only use Motorcraft filters. The same goes for the air filter.
5. Do not use any aftermarket tuners on your truck.
6. Get a scanguage and monitor the oil and coolant temps. They need to be within 15 degrees of each other. If it is more have the EGR cooler and the oil cooler checked. Cost is about $170 for the scanguage.
Enjoy your truck! No need to spend thousands on something that isn't broke.
This is a great list. I haven't seen this compiled together like this. I have heard of part of it like the coolant filter. I do have a question. What do you do if the Oil and the Coolant temps spread by more than 15 degrees?
Thanks!
Jeremiah
