DavinD wrote:
Wanted to add my .02.
My 06 F350 had 201,000 trouble free miles until it ruined my current vacation. EGR cooler failed in Houston and cost me $2600 to replace. Then on the way home one of the plastic boost hoses on the Turbo failed. While none of these did significant damage to the engine, it took all of the trust I had built up for my truck and threw it out the Window. It will take me some time to trust it again.
Not sure if I'm going to trade it in or not (assuming it gets me the rest of the way home tomorrow).
Sucks to keep reading about your troubles. I almost nearly certain the ruptured turbo hose is a result of over-boost considering the preceding repairs. This is because the failed EGR cause the Unison ring in your turbo to rust up. You need turbo rebuild to fix the root of the problem. I have seen this exact sequence failures first hand.
