tirerack.com wrote:
Today's load range/ply ratings do not count the actual number of body ply layers used to make up the tire's internal structure, but indicate an equivalent strength compared to early bias ply tires. Most radial passenger tires have one or two body plies, and light truck tires, even those with heavy-duty ratings (10-, 12- or 14-ply rated), actually have only two or three fabric plies, or one steel body ply.
In all cases, when changing tire sizes or converting from one type of size to another, it is important to confirm that the Load Index in the tire's service description of the new tire is equal to or greater than the Load Index of the original tire and/or that the new tire's rated load capacity is sufficient to carry the vehicle's gross axle weight ratings.
Curious what size tire you were looking at that the salesperson thought could handle the load. Did you have the camper on at the time? :)
