badger6724 wrote:
Well my batteries are fully charged and sitting at 14.2V off the charger. I will let them rest a few days and check the voltage again. Now my converter charger (Progressive Dynamics 9200) , when plugged into shore power is putting out 13.68V with no batteries connected. One poster, westend, said "Your PD charger should reach 14.4 +V. You want to make sure it does." Would that be with a battery connected? Is the voltage too low? Trying to figure out why the batteries were so low after being plugged into shore power for 6 weeks.
AFAIK, the PD converter will output 14+V when first connected to depleted batteries. How long that stage lasts, I couldn't say. My PD converter is much older than yours so has different specs. I'd suggest to monitor voltage at the batteries with the converter powered.
13.6 V is a good float voltage for the 6V in series pair and is also the no-load voltage. If you haven't done an equalize charge on them, you could look at the PD converter manual and see if it hits that every so often.
PD converter manuals
