sarhvac1
Mar 04, 2017Explorer
7.3 repair bill ouch
had my 7.3 to the dealer for Waste Gate actuator and heater fan stuck on defrost,,, $963.00 later runs like a champ. still cheaper than a new truck payment ok rant over!!
Stefonius wrote:
OP, I feel your pain. I'm about to open my wallet to have the oil pan on my 7.3 replaced. Most of my work is DIY, but for pan replacement I keep getting stuck on "Step 1: Remove cab from frame".
DiskDoctr wrote:sarhvac1 wrote:
I heard that chiping a 7.3 was not a good idea...
Chipping and Tuning are very different. Installing a canned, one size doesn't fit anything "chip" isn't wise for any vehicle, IMHO.
TUNING, on the other hand can be quite safe with modest performance gains.
cummins2014 wrote:sarhvac1 wrote:
I heard that chiping a 7.3 was not a good idea could be the reason you had problems with the Trans and hp oil lines honestly I'm not in that much of hurry to get where i'm going and I honestly never had a power problem then again my 5th wheel only weighs approx. 11000 loaded I climb hills doing 60-65 with out a struggle
I will put you on a couple hills with that 7.3 and 11k and I will guarantee you that it will be 35-45 in second gear . I know this because I towed those mountain grades with a 7.3
You may be pulling mild grades at 60-65 but you won't on the steep grades
