This is a ridiculous comparison. The 7.3 was a great engine in its day with a fantastic legacy but is does not compare to the 6.7.
Even if you try to compare the components as the article does you cannot separate the engine from the drive train.
The newer transmissions,exhaust brakes, beefier frames, greater towing parameters etc. makes the comparison so one sided there is no real comparison.
