Jayco-noslide wrote:
You didn't say what gear but probably 2nd? Sounds about right. 3,000 is not at all high RPM. It may sound like it only because we are used to cruising around 2000. 5,000 won't hurt an engine for short periods though usually not necessary. 3 or 4,000 RPM's would be better on the motor than "lugging" it up a grade at 1500 in a higher gear.
^THIS The computer is programed to shift early to squeeze every bit of gas mileage. So we are used to hearing the engine loaf along, only hitting maybe 3000rpm for a second before shifting, never really even hearing 4000 or 4500 at all. When you put a TT behind a gas engine truck and ask it to work climbing a hill, now you get to hear 3000, 4000, 4500 rpm a lot more because that is where gas engines make their power, especially small block SOHC. We are not used to this sound for more than a second or two, so it sounds like the engine is going to blow up. It is not, a gas truck engine with proper cooling will run at it's peak for hours if necessary and not hurt it.
