Hondavalk
May 14, 2018Explorer II
7 pin connector
2017 F250, the center pin of the 7 way has no power. I know it usually only activates when in reverse but still no power. Any ideas?
downtheroad wrote:
There should be a 30 amp fuse located in the number 27 position in the power distribution box under the hood. Check to make sure the fuse is not damaged or missing on your truck
Travlingman wrote:
The connector will not have power until the engine is running and you have depressed the break pedal.
