- CavemanCharlieExplorer IIIIf you are plugged in all the way and the door tab is holding the plug in and yet you still are getting a unplugged signal. Then I wonder if you may have corrosion in the plugs and need to clean them and then use di-electric grease.
Sorry if I didn't explain this very well. - BubbaChrisExplorerWe've had the "trailer disconnected" warning come up on two trips now. The first time we were going down the freeway and I have no idea why it happened.
The most recent one was on a fairly smooth road, but the first 4.5 miles away from the campsite was a dirt road. So that could have shaken the connector lose just a bit. (on the good news front, that road liquefied everything in the black tank)
I'll have to see about rigging up a small bungee as others have done. The 7-pin on the TV is was new a year ago as I made the dealer replace the original because the cover was missing. - mabynackExplorer II
schlep1967 wrote:
Another possibility is the cord is too short.I ran into this pulling a borrowed trailer. Every time I turned left it unplugged the cord.
It makes trip planning a little more difficult when you can only make right turns. - 2112Explorer III had this issue with my '97 Ford. It wouldn't fall out but it would lose connection. The TV connector was worn out and I had to replace it.
10by32 wrote:
I always secure mine with one of the mini bungee cords. Learned the Harry way what happens when it drags on the road for a while.
Me too. I now have an outlet in the bed of my truck and I trimmed the excess wire so it won't happen again. - Another possibility is the cord is too short.I ran into this pulling a borrowed trailer. Every time I turned left it unplugged the cord.
- samsontdogExplorer
I do the same as above - hawkeye-08Explorer IIII always connect and disconnect a few times before I connect to "clean" the contacts a bit and then make sure the cover secures the cord. I had some trouble when truck was new getting it in far enough to latch, but after some usage, it latched fine and stay connected. I carry the mini bungees and would use that if needed.
- kearlmsExplorer
nevadanick wrote:
Your not pushing it in far enough. The flap or door has a stop built into it that the keeps the plug from coming out.
I have a similar issue as the O.P., but it is not a matter of pushing it in hard enough. I can really but pressure on mine and it will back out a bit. Not enough to fall completely out but just enough to loose contact. I replace the one on the TV, been contemplating replacing the end on the TT.
I always make sure that the clip on the lid is holding the plug in. - icanonExplorer
X3
44,027 PostsLatest Activity: Mar 05, 2025
