RinconVTR
Apr 30, 2017Explorer
I pull nearly 7200lbs with a 1/2 SUV. A well set up WDH and air'ed up tires are huge. Power is a non issue, just be prepared to let the motor rev.
Its the length I'd be more concerned about for a TT of that weight.
Any cross winds, semi's blowing by, you'll know it and it wont feel great.
#1 - Make sure the WDH bars are rated for 1000-1400lb and get the front wheel ride height back to the unloaded height.
#2 - You'll want to air up your truck tires to max cold (44psi) if they are P rated. LT's would be better and run around 60-65psi.
44,068 PostsLatest Activity: Jun 09, 2026
