bovellois
Sep 01, 2013Explorer
97 cummins sucking air
The problem started with the engine stalling without apparent reason at idle. Then it got worse, the engine was running rough and the way to keep it from stalling was to feather the fuel pedal and keep the rpm up. I changed the fuel filter this morning, increased the engine idle and filled the tank right up (in case I got bad fuel), but now when I turn the engine off I see fuel dripping slowly from the frame in front of the fuel tank so I suspect a pin hole somewhere along side or at the top of the fuel tank, which would cause the supply line to suck air when engine runs. I'm 400 miles from home, not towing anything. I wonder if I could cut the supply line and bypass it with a rubber hose stuck in the filler hole and connected to the accessible part of the supply line in front of the tank. Any ideas?
