bovellois's avatar
bovellois
97 cummins sucking air
The problem started with the engine stalling without apparent reason at idle. Then it got worse, the engine was running rough and the way to keep it from stalling was to feather the fuel pedal and keep the rpm up. I changed the fuel filter this morning, increased the engine idle and filled the tank right up (in case I got bad fuel), but now when I turn the engine off I see fuel dripping slowly from the frame in front of the fuel tank so I suspect a pin hole somewhere along side or at the top of the fuel tank, which would cause the supply line to suck air when engine runs. I'm 400 miles from home, not towing anything. I wonder if I could cut the supply line and bypass it with a rubber hose stuck in the filler hole and connected to the accessible part of the supply line in front of the tank. Any ideas?
  • Funny you should mention that, but that was exactly what my husband said to mention to you when you came back.
    Over the years they had found that the 1996/1997's OEM's rubber fuel lines needed replaced a little sooner then other years. All of their company trucks of that year had to have those OEM lines replaced years ago. Our Dodge 2500 is a 1998 1/2, and he's not had those issues with it.
    So, the pro would be to replace all the rubber fuel lines as SOON as it's convenient to do so.
    The con is that you could be dealing with this issue until you replace all the lines. Hubby said to BE SURE and replace BOTH suction and return lines.
    We'll be up for a bit if you have any more questions.
  • Thanks. The truck is still running well at crusing speed so I'm just onsidering this in case it would get worse, as I can't see taking the fuel tank off, of going to a garage but there might be a way to get to the top of the tank to see where the leak is before doing anything. I would also be interested to get advice on pros and cons of replacing the OEM fuel line with a diesel grade flexible line, as the lines both in and return are getting rusted.
  • Hi,
    Hubby was a Cummins Diesel instructor for 35+ years. I just read him your post.
    He recalls that the Dodge fuel tanks have a baffle to prevent people from siphoning fuel... BUT.. if you can get the hose in and well connected (as you stated) it could just work to get you to a dealer.
    HOWEVER, there are certainly some concerns ATTEMPING THIS as it is a SAFETY ISSUE and you are taking some risks with this repair. Also, technically it's illegal to run like this, but it sounds like you're stuck and just limping in.
    Good luck...
  • Added info. When I let the truck sit for more than 10 minutes I have to use the hand primer before starting or the engine will just crank over and not start.
