brulaz
Apr 21, 2014Explorer
cptnjak13 wrote:
I have a 97 Golden Falcon travel trailer. I am in the process of replacing the rubber rood & have to also replace one sheet of plywood. My question is this. The current plywood sheeting is only attached to the rafters at the edges. The two rafters the run through the center of the sheeting are not secured with nails. Does anyone have any idea why this is? When I put the new sheeting on, I am thinking of scewing it fast, just curious if anyone knows why I shouldn't.
Glued? But even there you usually use a few nails to hold the two pieces of wood together while the glues sets.
44,066 PostsLatest Activity: May 13, 2026
