goducks10
Sep 29, 2015Explorer
What I notice about the 1/2 ton towables jargon is that usually they're towable in dry mode. The 1/2 ton towables have weights that are 1/2 ton truck doable when not loaded. Like 1300-1600lb pin weights. That weight falls directly under or at the payload capacities of most 1/2 tons. Problem is when you load em up they weigh more. That means most 1/2 tons are overloaded when towing 5th wheels.
You can get 1/2 tons that have high payload capacities if you order one. The ones on the dealers lots are under rated.
The other side to lite 1/2 ton towables is they're lite for a reason. That's because they don't use heavier materials and components. Lighter axles, thinner frames, less bulk in cabinets, etc. They won't stand up to the same usage as reg 5th wheels.
44,067 PostsLatest Activity: Jun 05, 2026
