- trail-explorerExplorer
jimbob3ca wrote:
Luckily as well, none of the other possible ignition sources in the camper ignited the propane, as that would have been a huge explosion.
And A fireball big enough to be seen from outer space! - notevenExplorer IIIBigfoot campers cannot withstand internal explosions - its a known issue.
I would not buy any camper that cannot withstand an internal propane explosion with "minimal" damage. - pjay9Explorer
HMS Beagle wrote:
pjay9 wrote:
Photomike, I am not certain about BF's but on boats the joint is usually stronger than the hull or the deck... the joints are mostly likely glued with a sealant then glass/resin taped to make it watertight, thus it become strong...now that is in a good boat. Cheap boats are glued with sealant and then a flimsy rub rail is pop riveted on the joint on the outside...nasty leak prone and not strong, but probably stronger than the rest...so I am not surprised the joints held is my point! But you may be correct! JMHO!!
That is why I have an all welded alloy boat!
Unfortunately, as good as Bigfoot is, and as much as I love mine, it is built far cheaper than a cheap boat. Not sure there is even sealant in there, it is just an overlapped seam with sheet metal screws driven through a flimsy aluminum rub rail. This is the RV industry after all....
Sorry to hear that! - HMS_BeagleExplorer
Unfortunately, as good as Bigfoot is, and as much as I love mine, it is built far cheaper than a cheap boat. Not sure there is even sealant in there, it is just an overlapped seam with sheet metal screws driven through a flimsy aluminum rub rail. This is the RV industry after all.... - Super_DaveExplorer IIDarn those mobile meth labs! LOL!
- joeshmoeExplorer III
pjay9 wrote:
That is why I have an all welded alloy boat! - joeshmoeExplorer III
bigfootford wrote:
this Bigfoot camper is going to leak.
A little lap sealant and it'll be good to go.
On another note, let this be a lesson about eating authentic Mexican food and trying light an appliance. Ventilation, ventilation, ventilation! :) - YukonersExplorerThat's funny right there Buzzcut:)
- SCVJeffExplorer
Photomike wrote:
I suspect one could argue that the weak point lengthwise of that camper is the doorway, and then one side or the other since thats where all the frame joints are. Looks like it opened up on the right side of the door.SCVJeff wrote:
When there is an internal explosion like that its going to split at the weakest joints, not at the point of ignition.
Fiberglass body, the weak point is the joints on the side where they join the top and bottom. I thought that it would have separated there as well. It did split on the left side at the seam. - Executive45Explorer IIIHe was at a WalMart...they carry acetone, iodine, toluene, and all kinds of other "needy" stuff.....the fact the guy was simply walking around gathering items makes me wonder what he was really doing when the thing blew up..my immediate response would have been to call 911...:h.....Dennis
44,056 PostsLatest Activity: Jan 22, 2026
