modern_family's avatar
Nov 30, 2014
A "blow out" of a thanksgiving trip!
Part 1.. We had our first blow out on the road last week. (We were on I-75) Not too much damage down below, maybe because I stopped immediately as I knew exactly what had happened and I was only going 60 in the right lane. Or maybe I got lucky..
I am a very prepared and organized person, I had everything to change the tire (so I thought) BUT, I didn't count on the highway shoulder to be at such angle that my truck jack would not work. (Meaning I felt it to be unsafe with all the sway from passing trucks and cars) In comes a Good Sam service about an hour and a half later with their 3 ton floor jack with no problem. My jack may have worked, but I didn't want to chance it.
Lesson learned, but, my question to any of you...
If any of you have changed a tire on the interstate, what have you used?
Part 2.., Here is the best part, leaving stone mountain, all packed up and pulling out of the site, our neighbor yelled for us to stop. As we were passing his site, both tires were quickly going flat as air rushed out if them. I immediately reversed and backed into our site. No one could figure out what popped them (nothing was in them and nothing was on the ground) This time, we were in a nice and flat area, so I took both tires off and had them patched at a nearby good year tire store.
4 hours later, as I installed the tires, the kids and the wife looked all around for what punctured the tires. Finally, under a bunch of leaves, my wife saw what looked like a tent stake in the ground nailed into a rail road tie. I called the office and they came down to take a look. No one had an explanation, so we just took some pictures, they removed it (not easily, they ended up just nailing back in) we made sure the office knew what happened and we had to get on our way, long trip back to Tampa yesterday.
So, 3 tires, one trip. BUT, we had a great time at Stone Mountain! one of our favorite campgrounds.
  • Yes, that happened to me one time. Side of I5 sloped downward and was soft.
    I ended up using the stab jacks to lift the side of the TT high enough that I could get my bottle jack under the axle (under shock mount).
    You see, stab jack CAN lift. ;)
  • If any of you have changed a tire on the interstate, what have you used?
    Started towing trailers for a living in the late '60s. I use a 12 ton shorty truckers special hyd bottle jack. It slides easily under the axle next to the U bolt on a std leaf spring suspension. It has a 10" x 10" base and a short legged U channel that cradles the axle so no slipping off the jack on the side of a highway or sinking in mud.
    All the jack does is lift one end of the axle (on any slope) enough to remount the spare. No sense in lifting the whole side of the trailer while on the side of the road.
    This old jack has logged way over a million miles in many different trucks with me and used on axles of all sizes up to 10000 lbs.
    Others have their favorite way of changing a tire on the side of a highway on a slope.
  • We just pull one tire up on leveling blocks and that raises the other tire.
    Only works on tandems though.
